I've been putting on some tuning miles on the 98, engine runs well besides a little knock retard and the seldom random misfire code. Today, for the first time ever, I got a P1870 code for component slip. It seemed that the TCC wanted to go in and out of lockup while cruising around 50 mph.
Everything in the trans has less than 10,000 miles on it - TCI clutches, rebuilt pump, beast shell, TransGo reprogram kit/plate, Trailblazer torque convertor, Corvette servo, etc. TCC check ball was removed when I went through the trans and installed the beast shell along with some other parts. Trans is behind a TR224 cammed LQ4 6.0 with headers.
I did some reading and set the TCC PWM minimum to 92% and the max to 100% (stock is 10% and 96%) which everyone said was recommended by HP Tuners. Other than that, all tables are stock 98 A4. I haven't ran it with the new parameters, yet. Looking for any suggestions. Does anyone have a similar setup and a HPT or EFIlive file I can look? [MENTION=860]sman[/MENTION]?
I'd appreciate any tips, tricks, and/or info! Thanks
