I have a 1999 camaro with a rear end from a 2002 that was swapped in before I purchased it.
Factory 2.72 gears, factory Torsen diff.
The problem is I have a leak from the right side axle seal and what sounds like a bad wheel bearing, also i may have "play" in the c-clips from left to right as I hear a "sheeep sheeep sheeep" sound that gets worse when turning.
I would like to fix everything and was quoted 550 from a local shop, this is much more than I would like to spend, I was really hoping it would have been like 2-300 to fix, 550 seems a bit high.
I'm considering doing the job myself. The only thing I have yet to do on a vehicle is mess with differential internals, or mess with transmission internals (beyond a valvebody or a clutch on a M6).
Any advice? The vehicle is driveable right now. I'm thinking I should do both wheel bearings and the pinion bearing... basically if I crack this thing open I want to do everything and be done with it.
