Rear brake lines
  • Rear brake lines
    Replacing my rear brake lines, the hard lines and I found these and wonder if they'd work to replace the hard line and the rubber line. For a 98 camaro with discs
    http://m.summitracing.com/parts/wil-220-6856/media
    Those only replace the flex line.
      This^
      I just did mine when I swapped my rear, much easier when its out lol but its a great piece of mind.
      2002 Z28 Camaro A4
        Do they have anything that they sell to replace the hard lines. Really don't feel like bending them myself and not to sure how you go about the fittings needed
          I don't think they sell a direct replacement. It isn't hard to do it... Go there and they will give you female connectors. Take your soft line in and they will give you the correct fitting. It really isn't bad.
          2002 Z28 Camaro A4
            I believe In-Line tube has all the lines available and they are local.
              +1 for InlineTube.com - they're located in Macomb Twp. Can't remember if they're off Hayes or Schoehnerr but it's one of those two roads... and they're between 22 and 24 mile rd.
