Brake offset
  • Brake offset
    I'm about to order rear brakes for my 98 camaro, I have a ford 9" stock length and race stars, I need to know what offset brakes do I need?
    Thnks
    You have to measure yours. The offset is from flange to bearing retainer
      Thanks, sounds dumb but what flange?
        The brake manufactor should have instructions online. It's like from the axle flange(rotor surface) to where the bearing retainer is.
        Some just say if you have this end they will work and come with a bunch of spacers to center the caliper over the rotor once installed
          Well if I'm orderin the whole brake kit it should be centered right? I'm just worried about it not clearing my rims.
