am I stupid in the fact that I am wondering what is going on in the thread? The "turn test" as it was reffered to is basically fool proof. my driveshaft turns 4.10 times for every 1 revolution of the tire, and I do have 4.10 gears lol. Not sure how a 4.10 could be any different????? Likewise, any other gear??? there could be issues if you turn the tires, such as having a torsen diff, but that's another issue in itself... just turn the driveshaft...
Gear Ratio RPM issue
its easy on a posi to tell but on an open i could see it being a tad harder still marking it up with chalk is the easiest way to find out without pulling the cover off... even so if it does have something other than stock i guess it would be a good idea to catch which brand gear you have in there and then just replace the seal and add some nice new synthetic gear oil when you put it back together... with the tranny fluid and rear end oil swapped to sythetic i got an extra 2mpg and you can feel how much smoother it is... so its not like its going to hurt anything to pop the cover off just to take a peek..Originally posted by Frank The TankTook the restrictor plate off to give the Red Dragon a little more juice. But it's not exactly street legal, so keep it on the down low.
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
- Mechanical Designer
Well, solved the mystery. Just got home and checked the door. GU5 is the code, which is the performance axle option. So I have 3.23 gears, which also explains the aluminum driveshaft. The math doesn't quite work out with the calculator, but now that I know what it is I guess that really doesn't matter.
Anyways, very pleasantly surprised to find this out!!!!
i think you should be lower than 2800 at 80 mph though... my truck turns like 2300 at that speed... granted it has taller tires and 3.73s, idk how that would balance out.-Joel
Nope, I'm running 2.73's and turning 2100 rpm's @ 80 mph. It's 3.23's.Originally posted by JoeliusZ28i think you should be lower than 2800 at 80 mph though... my truck turns like 2300 at that speed... granted it has taller tires and 3.73s, idk how that would balance out.
Jasen, you should have just looked @ the driveshaft from the start.
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
I knew the driveshaft was aluminum, I just didn't know till I did some research yesterday that it meant I had 3.23's. Oh well now I know, one less thing I have to change now!!Originally posted by zspot98Nope, I'm running 2.73's and turning 2100 rpm's @ 80 mph. It's 3.23's.
Just wanted to Add that those Axle Calculators sometimes need your gear ratio from the trans. 3rd gear is 1 to 1 on Auto's 4th is like .76 so that may explain the differences.CraigSemi Retired Street Racer2012 Lava Red Mustang GT 5.0 MT82GONE BUT NOT FORGOTEN
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
- Smokey Yunick
2010 Yukon Denali
