motor mounts
  • motor mounts
    i have been debating on what type of motor and trans mount to get i was thinking solid for the fact that they will more then likely never have to be changed. i know that it will make the ride more uncomfortable. or i was thinking the prothane mounts.
    what do you guys have or recommend or what are you using
    98 ss camaro m6
    -cammed, headers, borla exhaust, mti lid
    366.66 rwhp - 351 rwtrq
    04 lancer evolution
    -minor bolt ons, tune
    currently my dd
    Whatever you do up front, I like to go down one step for the trans
    Unless stock of course
      I recommend stock rubber mounts.
      Solid engine mounts are for tractors and dragsters.
        Poly motor and rubber trans... poly trans and u will have alot more vibrations
          Yup. I have this on my Iroc....wish I didn't sometimes!
          Don't go solid up front unless you need it. Don't go poly trans unless you need it.
            Solid front abd rest never have to change them. Its a racecar anyways lol.
              I understand that comforability will no longer be there but I'm looking for supporting mod I don't want to have to change the for a long time I ripped the stock trans mount when I first put my 315s on the rear end
              98 ss camaro m6
              04 lancer evolution
              currently my dd
                Every LS1 car I've ever been in with Poly motor mounts feels like factory. I'm surprised you have a problem with the 3rd gen.
                I would go poly motor and rubber trans.
                  My buddy has poly all the way around even on the trans and its not to bad but you can tell the difference in the vibration
                  98 ss camaro m6
                  04 lancer evolution
                  currently my dd
                    The Iroc is poly all the way around. The 98 is poly front, rubber trans...but I haven't driven that one yet
                      Have solid motor mounts and poly trans. The cars really does not feel any different than when it had poly mounts at the engine and trans. My old Lumina actually vibrated more when it had a busted motor mount
                        100% agree on softer for the trans that the engine mounts. Had a poly trans mount and it wasn't too bad, switched over to poly motor mounts and couldn't stand to drive the car. Had a few buddies that are mechanics ride with me and they all commented on it. Switched to rubber and it went away immediately.
                          This is one of those topics i cant agree with the status quo... Unless its a M6/A4 thing. I have stock engine mounts and a poly trans mount. I dont notice any vibrations. I tried going back to a stock rubber trans mount because of discussions like this and it was miserable. The shifter bounced around on holeshots and i believe it amplified wheel hop. So i put it back to poly and decided I am happy with the configuration I have. Every car is different though. Trans/clutch/stall as well as suspension can play a direct role in what works best. Components should be selected as components of an overall system, not just "this part is always best"
                            on my camaro i had solid motor mounts and a poly trans mount. the only difference i felt was the trans never moved. everything felt nice and solid.
                              As someone who is going to be buying motor mounts in the coming months, this thread confuses me even more lol.
                              Ill probably just stay stock on everything and play it safe.
