Ok, I was planning on breaking the bank and buying a Moser this winter. As of now it doesn't look like the budget will allow, so I'm thinking of buying a used third gen posi rear and rebuilding it. Anyone have any suggestions or tips? I know that there is one that is pretty hard to find parts for. How do I tell them apart. Have any of you guys put any big hp to one of these? Will it last? Which one do I want? Are there any years that are better than others? I can buy a complete used rear end from Hawks Third Gen for like $300. Does anyone have one laying around that they will let go for cheap? Thanks for the help guys!
Third Gen rear end questions
Obsessed- June 6th, 2012
- 505
- Brian
- 1991 Camaro RS/1991 Camaro Z28
- Wixom Michigan
- Truck Driver
- 505
- Brian
- Wixom Michigan
- Truck Driver
Thanks Shawn. If I buy an axle and housing package I will still have to buy the posi unit, which wont be cheap.. Trying to stay as economical as possible. I'm seeing a lot of these guys with turbo cars on youtube with factory rear ends. I know its only a matter of time once I start hooking the tires up, but I'm thinking I can build one that will last with 450hp or under for a fraction of the the price of the Moser I wanted. This is why I'm asking questions though.Originally posted by shawnc16 View PostIMO I wouldnt waste the money. By the time you have a built 10 bolt rear, you arent too far off from picking up a housing and axle package. Save some money over winter. 10 bolt is a wastesigpic
What kind of power level?
Sent from my iPhone 5 using Tapatalksigpic
I agree I would not dump money into one either but what is your power level? Gobs of torque and traction break rear ends. A stock 10 bolt can actually last a while with a good set of gears and a girdle/cover. I've had the same 7.5 10 bolt in 3 g body cars for a lot of passes and a lot of power. The cars have ran anywhere from 14's to high 11's. Albeit the rear end ran on luck for the most part haha but still they can actually take a decent amount of abuse. If you are stock I wouldn't bother using anything other than a 7.5 10 bolt.95' Formula: A4, 3.23'S, K&N CAI, Granatelli MAF, Trickflow Elbow, tune from previous owner. Best 1/4 of 13.91.
Originally posted by deeznuts94 View PostI know its only a matter of time once I start hooking the tires up, but I'm thinking I can build one that will last with 450hp or under for a fraction of the the price of the Moser I wanted. This is why I'm asking questions though.
Thats the thing. They will work and then all of the sudden not work haha. Can they handle high power abuse? Sure, but not reliably like an S60, 9", 8.5 10 or 12 bolt.95' Formula: A4, 3.23'S, K&N CAI, Granatelli MAF, Trickflow Elbow, tune from previous owner. Best 1/4 of 13.91.
Build the engine first, then see what breaks! I had 3 summers of 12.x on my stock 2.73 10-bolt without any issues (Automatic, 415 rwhp, went as fast as 12.2). It didn't break until I poured money on it with 3.73s, auburn posi, moser axles and c-clip eliminators. I didn't set it up and I don't think it was done correctly but that's besides the point.Originally posted by deeznuts94 View PostOk, I was planning on breaking the bank and buying a Moser this winter. As of now it doesn't look like the budget will allow, so I'm thinking of buying a used third gen posi rear and rebuilding it. Anyone have any suggestions or tips? I know that there is one that is pretty hard to find parts for. How do I tell them apart. Have any of you guys put any big hp to one of these? Will it last? Which one do I want? Are there any years that are better than others? I can buy a complete used rear end from Hawks Third Gen for like $300. Does anyone have one laying around that they will let go for cheap? Thanks for the help guys!
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Could be a lot of things that caused that rear to break, but shock load is the biggest killer of 7.5/7.65 rearsOriginally posted by scholtmj View PostBuild the engine first, then see what breaks! I had 3 summers of 12.x on my stock 2.73 10-bolt without any issues (Automatic, 415 rwhp, went as fast as 12.2). It didn't break until I poured money on it with 3.73s, auburn posi, moser axles and c-clip eliminators. I didn't set it up and I don't think it was done correctly but that's besides the point.
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Rear girdle cover? Seems to be the caps or shearing teeth usuallyOriginally posted by scholtmj View PostBearing caps broke to be specific.
- 505
- Brian
- Wixom Michigan
- Truck Driver
Thanks for the opinions guys! As for power levels, we are planning on building a 406 for the car. I already have the rods and pistons, looking for a block at the moment. I wouldn't think any more then 350-450 hp. The car has a stock open wheel diff in it now, however I did stuff some 373 gears in it that I had laying around over the summer. The gear set made a huge difference in the car, but without the posi it isn't any fun. My thought was taking the money I was planning on spending on the rear end and buying the pieces for the motor, instead. With the plan of putting less than a grand into a stock posi rear.sigpic
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Maybe find a used Zexel Torsion rear diff for $150-200 and call it good for now? Just a thought (and the route I went)
- 505
- Brian
- Wixom Michigan
- Truck Driver
