Need 4l60e help
  • Need 4l60e help
    I was pulling my transmission out to freshen it up some.
    Noticed on top on the input drum there was a weird orfice.
    On my other spares there is a different capsule with a check ball in it.
    Also found a check ball capsule in my spare parts...
    Not sure when/why it was put in.
    Any input in appreciated!
    1996 Base Model
    +2 cylinder mod
    People remove the check ball for quicker converter lockup
      I thought that was the one in the end of the input shaft?
      1996 Base Model
      +2 cylinder mod
        I posted this up on tech too.
        I guess I must have put it in as it is part of the HD2 kit.
        Originally posted by mrvedit
        It is the 3/4 clutch air bleed orifice. The idea is that air can escape before
        the hydraulic fluid seals the check ball and thereby can pressurize the 3/4
        clutch.
        Many performance builders will say that the check ball will unseat at
        high RPM (6000+ ??) and therefore create a major leak leading to 3/4 clutch
        failure. Therefore, some builders remove the stock orifice and replace it with a
        simple, much smaller bleed hole. The Transgo HD2 kit includes such an orifice.
        Another company makes a spring-loaded orifice, but in my measurements it was too
        big and could touch the reverse drum.
        Hopefully this answers your
        question.
        1996 Base Model
        +2 cylinder mod
          That sounds right. I revoke myself from trying to provide any information after 8pm I don't think logically well at night anymore
