I currently have a 350 and was wondering if I sent it out to a machine shop if it could be turned into a 400 or 455 seeing how I believe all Pontiac blocks started out the same. Obviously I would have to swap the crank, pistons, and upper end etc. but is it possible?
Pontiac 350
Obsessed
- January 13th, 2006
- 593
- C
- It's a big pretty white plane, with wheelz, curtains in the windows and it looks like a big tylenol
- MI
- Engineer
You can find Pontiac 400's ready to go and running if you do some searching. I found a few for around $300 complete, but they are high mileage pulls generally.
Even better, there are 421's out there too...but theyre pricy. Same with 455's.
A 389 tri-power in that 68 would be a blast.
If you do find a 400, you should look for a set of 326 iron heads. If my memory serves me right, they bolt onto the 400 and raise the compression into a healthy 10:1. (Any devout Pontiac guys confirm this for me?)
That would be the dirt cheap route to go.
http://flint.craigslist.org/pts/3187772676.html
http://flint.craigslist.org/pts/3153278685.html
http://flint.craigslist.org/pts/3172587885.htmlLast edited by TrickyTransAm; August 19th, 2012, 07:36 PM.
