Originally posted by c0ncEpT
View Post
trying to decide what axle to run
well it not to much work to narrow the 8.8
just get it out of a explorer take the long tube out and swap it for the short tube off a donor and weld or hack off 3ins off the long tube and weld all your stuff back on and use the short end axle and drill your chevy lug pattern
this is what ill probably do
but i can run the 8.8 un narrowed and run vette wheels and be golden just have to move the perches 1/4 in outwards
so we will see.
one question tho
if i run disc in the back and if i have drums now will i have to change the master cylinder or something
Originally posted by sniperperformance View Postmikes right. i was thinking about the dodge 8 3/4 sorry those fit nice to but you have alittle more work to do with them.05 cts
01 silverado 2500
96 s10 blazerrr
84 k5 blazer
all you should need is a proportioning valve.Originally posted by t_ank View Postwell it not to much work to narrow the 8.8
so we will see.
one question tho
- Lowell, MI
- Meat Processor
Yup, a disc/disc prop valve (easily found for s-trucks) will make it work. Not sure of the total width after all mods. I know some mopar 8 3/4 rears are really close to the same dimensions though.Originally posted by t_ank View Postwell it not to much work to narrow the 8.8
so we will see.
one question tho
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
make sure the tubes your gonna swap are the same diameter91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
yup thats why i started useing the 8 3/4 mopar rears. there strong and theres alot of parts out the for them. heres a picture of my olf LT-1 S-10 that later was swapped to a LS1. this truck has the 8 3/4 rear with drum brakes. they do make disk kits for it. i had the origanal ZR-1 wheels on it with not spacer in the back later i did a 1" spacer in the rear and a 1 3/4 in the front lowered the truck 3". ounce i swap out the lt1 for a ls1 the truck sold with-in 3 days. that truck was ruff but i replaces all the bad metal and painted it.
really close to the frame
couldnt find any pictures of the rear in it. i may have some on a thunb drive at home but its a easy swap.
- Lowell, MI
- Meat Processor
I want to say some 8 3/4 rears were 54"...am I mistaken?
they where 51"-59" and some changeOriginally posted by hoogiesngrinderz View PostI want to say some 8 3/4 rears were 54"...am I mistaken?
S-10 axle widths
2wd 54.5"
4wd 59"
ZR2 63"
dodge 8 3/4
All 8 3/4 E-body 63.40 1971-1974 YearAxle(A)(B)(C)1963 - 19727 1/4" A-Body 53.200"43.02"10.09"1973 - 19767 1/4" A-Body 51.400"43.02"10.09"1973 - 19768 1/4" A-Body 51.400"43.02"11.69"All8 1/4" B-Body 57.800"47.30"11.69"All8 1/4" C-Body 59.200"47.30"11.69"All8 1/4" F-Body 54.340"44.46"11.69"All8 3/4" A-Body 51.400"43.00"12.35"1962 - 19708 3/4" B-Body 55.000"44.00"12.35"1971 -19748 3/4" B-Body 57.800"47.30"12.35"All8 3/4" E-Body 56.500"46.00"12.35"1971 -19748 3/4" B-Body S.W. 59.200"47.30"12.35"All9 1/4" B-Body 57.800"47.30"11.69"All9 1/4" C-Body 59.200"47.30"11.69"1966 - 19709 1/4" B-Body 54.936"44.00"13.47"All9 1/4" E-Body 56.500"46.30"13.47"(A) = Flange to flange. (B) = Leaf spring centerline to leaf spring centerline.. (C) = Centerline of axle shaft to centerline of rear universal joint.
Illustration & Information from Chrysler Performance Upgrades, by Frank Adkins. Published by CarTech as part of their SA Design series.
- Lowell, MI
- Meat Processor
Looks like that's the info that Travis needs to make a choice for his ride
Anything 8 3/4" and above will last behind his setup and then some.
The factory 10 bolts are not junk, just the way some people drive causes issues. Sure if you have a lot more that stock engine you may want to up grade. Remember that Bragg-Smith driving school used 4th Gen Camaro SS' all of the time and did not see trans or rear end failures.
