Real Quick: Do I need a new Axle (Pics)
  • Real Quick: Do I need a new Axle (Pics)
    So I am replacing my bearing as we speak and everything is going smoothly. I know quite a few people say the axles need to be replaced after the bearing wears out. So I pulled my axle and took a couple of pictures. I have no references on what a good one looks like and what one that needs replaced looks like, so I am asking your guys/gals opinion.
    Stick a fork in them...there done.
      toast
        I have a set if your looking I can get you pics if you want.
          What's it supposed to look like?
            it looks not only pitted but also worn, I would bet you can feel a decent lip where that axle bearing was.
              thanks - never seen an axle before so wasn't sure what it should look like
                Thats exactly why I posted this and asked. There is definitely a dip in the axle, so much so that I wasn't sure that it wasn't suppose to be there.
                Detroitmuscle, hit me up when you can since I am going to need them. Well actually one, mcalus replaced the other side before I bought the car.
                Also if you can post up what a good one looks like, because even though this seems like its a common problem on these cars there are not a lot of detailed pictures about it.
                  Yeah that thing is bad. It should be smooth all the way across. The pitting in the "groove" is from excessive wear on the bearing surface.
                  -Homer Simpson
                    I went and took a good look at both and its a good thing your only needing one because one of mine is pitted as well here is a pic of how the axle should look and then second is the pitted one.
                      I didn't know the stock 10 bolt's lasted long enough to wear out bearings...I guess I learn something new everyday
                      Here's the correct way to fix the problem
                      http://www.hawksthirdgenparts.com/ca...wposiunit.aspx
                        Do you need the reluctor ring? on the axle?
                          they can easily be pryed off and reinstalled I removed mine and installed them on my mosers.
                            ah ok. I have a set of axles that would work as well
                              Thats all those things cost? lol
                              I guess if you guys have the axle shoot me a PM on the price, and i'll come and get it. My wife just asked, "How long is the garage going to be like that?" lol
