Bent axle? Vid inside
    Originally posted by Lucky SOB View Post
    might as well replace both while you're doing it right?
    That be the plan. I need to borrow one of Brent's money trees.
      Wait, he has more than one? Dibs if he has another spare! Haha.
      Well, at least axles arent TOO huge of an ordeal. Obviously theres cost involved, but its not like your ripping the whole car apart to change them.
        He has several trees. Yea, at least the rear can stay in. Will get em pulled this week, maybe.
          when you order them dont forget to have them put the 1/2 inch studs in them now
            Moser can straighten axles for $ 50... http://www.moserengineering.com/moser/shop-services/
              Yes sir!
              Thanks, but no thanks..
                I would not buy moser axles if you are shopping for new ones
                  I was planning on strange..
                    How many splines are your axles?
                    I met a guy last week on Woodward that told me he was the first person ever to get a F Body BMR K member and a bunch of other stuff. He said he runs a Moser 12 bolt and it will hold 2500hp and if he could break it Moser said they would buy it back from him. I was like oh yeah considering a 9" and a Dana 60 are stronger and are only rated to ~1500hp.
                    Oh and his engine was stock. He didn't even put heads or a cam in it.
                    Originally posted by Yoshi94
                      never once had a problem with mine..
                        Sorry to hear about the problems, Larry. Maybe if the seller doesn't get back to you, you should just toss the bad axle through the front window of his house.
                        When in doubt, Whip it out !
                          He is in Nebraska. Or I would.
                          Originally posted by Fox Slaughter View Post
                          How many splines are your axles?.
                          31 spline.
                            Damn Larry that's bad. Looks like this good deal is turning into a even bigger headache.
                            Atleast they're easy to replace.
                              Yea, I'll still be under new price, but not by much. Lol
                                let me borror it. bet it only makes it 100 feet
