3800 Bolt Part Numbers
  • 3800 Bolt Part Numbers
    Where's the best place to get part numbers for replacement parts?
    The local dealer's will not give them out.
    For an 01 3.8L I Need:
    Connecting Rod Bolts
    Main Cap Bolts
    Cam Bolt
    Crank /Harmonic Balancer Bolt
    Flywheel Bolts
    Balance Shaft Bolt
    ARP makes the Rod bolts, but they are hella expensive for a stock application.
    I don't believe they make them for the main bearing caps.
    Because all of these fasteners can't be re-used (Torque to yield), I need to replace during my rebuild.
    Anybody have any leads to help me out?
    my local bob sellers is very friendly with part numbers, i go in there all the time ad then order the parts elsewhere like gmpartsdirect.com if shipping time isn't of concern.
    http://www.sellersgm.com/
    ~Phil
