While working on my 2002 TA (86,000 mi) to replace the rear axle bearings, I pulled out the axle and noticed what to me seems to be heavy pitting on the axle shaft where the bearing mounts. I took a photo to illustrate, and am wondering if this is actually excessive, or if this is simply normal wear and tear. Do I need to replace the axle? I have no idea how long the bearing has been bad.
Also, once I got the seal and bearing off, I noticed that the 'lip' that the bearing was resting against was much thinner at the bottom than the top (picture also attached). The diff oil had alot of metal shavings in it, and combined with the axle pitting and no idea how long the bearing has been bad made me wonder if the axle may have been rubbing on the bottom. I have no idea as I've never done this repair before, but since I was asking about the axle I wanted to find out about this as well; any reason to be worried? Or just business as usual?
