Mcleod rst twin disk
  • Mcleod rst twin disk
    Has anyone ran this clutch? I'm pretty much set on this clutch for my ws6, I keep reading good things about. Stock like pedal feel and great holding power. I think it's rated at like 800hp...
    Theres also the rxt, which is rated a bit higher but idk if I'll ever need that one...
    Superman09 runs this clutch in his cammed vette.
      Well I went with this clutch so I'll see how it goes I'm not making much power atm, but after the d1sc goes in, we shall see how this clutch does!
      BTW what kind of flywheel would be best if anyone can recommend something?
        i have a spec billet steel with about 300 miles(under 500 for sure) $100
          Are there any real benefits to a lightweight flywheel if you mostly drive on the street Larry?
          Used to own a Firebird.
            you dont really want a light flywheel on a unheavily modded car. the weight of the stocker helps get the car off the line
              I'm going with a McLeod steel flywheel.
