Okay so im in the process of taking my motor out to fix a few problems...well im sick of my abs unit being in the way. Especially since it doesn't work anyways. So how do i go about getting rid of it? What do i need...or have to do with all the lines that used to go into the abs unit? Thanks for any help and advice.
Nick K.
There is a company that makes a ABS delete kit for these cars. The company is called SJM manufacturing. The kit is less then $200.00. If you dont wanna do the kit then you can look at there kit and get some ideas! Also if you delete the abs you will want to put in an a adjustable proportioning valve to corrects unbalanced front/rear braking pressure that you would get when deleting the abs.
It is fairly simple. You need an adjustable proportioning valve and either y blocks or tee fittings to connect the brake lines and add a line lock while you are at it. Or get the kit from SJM.
It really does help to clean up the engine bay. Did mine last summer. The brakes work great and I love the room.
97 30th anv Z28 Lt1 Ported Heads and Intake, small Cam, LT's, SLP LM1 w/power flow conversion and cut out, Stalled A4, 3.73, 125 shot or so......... Custom EVI Tune and more to come...... SOLD
1971 Suburban work in progress
1969 Mach 1 In restoration process
Waiting to find the right Fbody
[QUOTE=chubbz155;578157]There is a company that makes a ABS delete kit for these cars. The company is called SJM manufacturing. The kit is less then $200.00. If you dont wanna do the kit then you can look at there kit and get some ideas! Also if you delete the abs you will want to put in an a adjustable proportioning valve to corrects unbalanced front/rear braking pressure that you would get when deleting the abs.
I know its always in the way, it scratches my slp intake, and it doesnt work so i just figure i might as well get rid of it. I really need to come down there and look at your guy shop and get some springs...you guys install springs to?
adjustable proportioning valve... hmm i just did my abs delete this winter and didnt use one.. interesting my brakes work good though... when would i see a difference in brake pressure?
I know its always in the way, it scratches my slp intake, and it doesnt work so i just figure i might as well get rid of it. I really need to come down there and look at your guy shop and get some springs...you guys install springs to?[/QUOTE]
Yes we do install springs. Come on down and see us. Take a few minutes and check out the shop. There is always something cool siting around.
Yes your brakes will work without the adjustable proportioning valve but will not be 100% correct. The adjustable proportioning valve gives you the ability to properly adjust the pressure to the rear brakes.
i have deleted a few. Used to put prop valves in but lately havent been . If they are stock brakes it should be ok. Mine and many others stop fine from 140+
So all i need to do is hook my front brakes together in a T and put my rear right up and/or use a proportioning valve with rear?
yeah. i use T's with an eyelet on them and screw them to the Kmember. I havent done any lt1's so a prop valve might be a good idea. just put the valve inline with the rear line. try not to make that valve higher than the master or it will be a pain to bleed
Alright thanks man! Ill pick up a valve, a tee, and go rent the tools from auto zone and see how it goes
