Ok here's the situation:
The rear is the only piece in the car, rear wheels on on the ground. I can turn the yoke on rear end about 1/8 of a turn back and forth. Does this seem like too much play? Is it even a problem?
Im guessing that the extreme wheel hop I had at Milan (which took off my wheels studs) might have been a possible cause.
So should I take the third member out and re-set the backlash/contact pattern?
