How can you tell if your pilot bearing and or throw-out bearing are heading south?
Pilot bearing, throw-out bearing question
If your pilot bearing is going out you would hear a noise mostly when the clutch pedal is depressed to the floor... because the flywheel is still spinning but the input shaft will not be therefore making a noise from the pilot bearing...
if your release bearing is going south then you will hear a noise from it when you start to depress the clutch pedal, due to it contacting the release fingers when slightly depressed.98 NBM Z28 A4 Cam ONLY 11.94 at 113 1.7 60'
233/239 .598/.603 113 LSA tuned by me, 3500 TCI SSF
turbo build in progress... Build Thread
Body repair build thread
TEAM LSWON
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
What he said
