4th gen peddle assembly
  • 4th gen peddle assembly
    Is their a difference in the peddle assemblies on 4th gens lt1 vs ls1?
    Not as far as I know. They should be the same. Hope this helps, Eric L
      on the v8 cars, no, but there is on the v6's.
        So the difference is in the master cylinder or after? I know one has a fork and the other has a hyd throw out bearing. I think? I am trying to get it figured out before I start the swap.
          Since your using a v8 for the swap, id use v8 pedals and hydraulics to keep it simple. Eric L
            That is what I was planning but wasn't for sure on the years I could mix and match if I couldn't get it all from one donor car?
              I would think so, but idk for sure. Sounds like Eric has it under control
