94 Trans Am axle in my 98 Z28?
  • 94 Trans Am axle in my 98 Z28?
    Looking at putting a 94 Trans Am axle in my 98 Z28
    The TA was a LT1 - 6 speed
    My Z28 is Auto w/ ASR and ABS
    If not, are the parts inside interchangeable?
    Something inside my 10 bolt is toast (horrible noises during deceleration, 25mph and down)
    I heard about the 3 / 4 channel thing, don't know anything about that, so I couldn't tell you what my axle is
    All I know is both are 10 bolts out of 350ci f-bodies, one m6 one a4.
    Thanks
    2004 Cummins 3500 4x4 QCSB Auto, 5" Exh, CAI, 20" GunMetal7s, 35" Goodyears, Fender Flares
    03 Z71 Loaded, Bose, Htd leather, etc
    (Sold)
    00 Camaro Z28 M6 T-tops (Sold)
    00 Camaro SS A4 T-tops (Sold)
    99 C5 Corvette M6
    (Sold)
    98 Camaro Z28 A4 Coupe
    (Sold)
    98 Camaro Z28 A4 T-tops
    (Sold)
    96 Cummins 4x4 36lbs boost
    (Sold)
    there the same besides the backing plates for the brakes.
      It has to be the same 3/4 channel as yours. This is easily determined, if you have TCS or ASR you have a 4 channel if not then its a 3 channel.
        So do I have to use a 4 channel axle? (My car has ASR)
        or can I use a 3 channel parts in my axle? Or should I just find a 4 channel axle?
        (Sold)
        99 C5 Corvette M6
        (Sold)
        (Sold)
        (Sold)
        (Sold)
          One other thing to consider, the gear ratio's are different. The auto is a 3:23 and the manual is a 3:42. Your going to have recalibrate the speedometer, if you care to do so. Just a thought!Rick
          Never complain,Never explain.
          Member Eastern Michigan Camaro Club
            i believe if you have a 4 channel you need to replace it with one, or lose your ASR.
              Just got word the donor car had both ASR and ABS
              So I should be all set, I'll be recalibrating the speedo via EFI Live
              So can I just use the stock brake brackets off of my axle? or do I need custom ones? Or can the 94 brackets be modified easily to make work?
              (Sold)
              99 C5 Corvette M6
              (Sold)
              (Sold)
              (Sold)
              (Sold)
                not entirely true...my a4 came factory with 3:42 my mom's m6 came factory with 3:23
                  My car has a 3.73 currently anyways.
                  Not sure what is messed up inside..... I just know it's not drivable anymore. Well it is, but makes loud horrible noises.
                  Is it possible it could be just the gear? or no?
                  (Sold)
                  99 C5 Corvette M6
                  (Sold)
                  (Sold)
                  (Sold)
                  (Sold)
                    Got the axle today..... anyone know if the 94 lt1 axle is wider than a 98 ls1?
                    And anyone know how to get the 98 brakes to fit a 94 axle?
                    thx
                    (Sold)
                    99 C5 Corvette M6
                    (Sold)
                    (Sold)
                    (Sold)
                    (Sold)
                      thx
                      Read my earlier post, i said you have to change the brackets for the brakes lol.
                      there the same width exactly, 10 bolt to 10 bolt.
                        So I can just use the brackets from my 98 axle? They bolt right up?
                        (Sold)
                        99 C5 Corvette M6
                        (Sold)
                        (Sold)
                        (Sold)
                        (Sold)
                          Anyone know how to get 98 brakes to fit a 94 axle?
                          (Sold)
                          99 C5 Corvette M6
                          (Sold)
                          (Sold)
                          (Sold)
                          (Sold)
                            Didn't think that was possible on either end. I thought the only A4 cars that had factory 3.42's were those optioned V6 cars. And all M6 cars had a 3.42 unless it was a 93' in which case it had a 2.73
                              They should swap right over.
