Ok, this past weekend I went home and was tinkering around the garage and noticed my car had a small puddle of fluid under it, near the rear axle. (its been sitting there in one place since mid-september). I got under the car and checked it out, and i can say that it is definitely be coming from the rear end, but not where i would have expected... The entire u-joint assembly ahead of the pig was basically wet, and it was where the car had been dripping from. However, the pinion seal and the axle pig was 100% dry.... Normally when I have seen an axle leak from this area, it seaps out at the seal and it drips from the pig. Not the case however, It looked as though fluid was dripped on the u-joint from above, which obviously did not happen so it looks like the fluid must be exiting through the pinion/yoke itself. Would thread sealant on the yoke nut have made the difference? Ive never seen a leak like this before.
I mentioned it my dad, he crawled under the car and had the same reaction as me ('what the hell?'). Also my car has a relatively fresh pinion seal - i replaced it a year or two ago and installed it properly using a soft piece of wood and gentle taps with a hammer. Never noticed any leaks before until now. Its an extremely slow/minor leak but id like to fix it anyway.
I dont have any pictures, i forgot to take my camera home.
ideas/suggestions?
ideas/suggestions?
