Trans lines
  • Trans lines
    So i had to replace some broken trans line and know i dont remember which one goes where. A friend told me that i can put the lines on eitherof the two hook up. I would like some one to tell me if this is true or not.
    Well... I'm not sure if that's 100% sure or not but I can tell you that the line that has the longer rubber hose on the end of it is the one that goes in the top hole on the transmission and the top port on the radiator. I honestly just lined them on the radiator and they just "lined up" to the right holes.
      Ok thanks that what i needed to know. I just went out and hooked mine up like that.
