Has anyone adjusted a Spohn Adjustable Torque arm? I had a 4 weel alignment on my car a few weeks ago and ever since then I have a horrible vibration over 80mph. I am hoping the alignment messed up the adjustment of the Torque arm or it is just out of adjustment. I have a rough Idea but never done it before. I didnt even know my car had the Torque arm untill a friend looked under the car and told me about it.
Torque arm Adjustment
InActive Member
- April 11th, 2009
- 274
- Christopher
- 1998 Trans Am
- Battle Creek, MI.
- Managed Services System Engineer at NuWave Technology Partners
1998 Pontiac Trans Am LS1, Ram Air, White with custom Ghost Flames, Black Leather Interior, T-Tops, T56 Trans, 4.10 Rear End, Spohn Adjustable Torque Arm, Line Lock, Kooks Headers, Kooks ORY Pipe, SLP Loudmouth II catback, LS6 Intake, K&N Air filter, Centerforce Dual friction Clutch, Lowered and "Conklinized"
Pioneer D3 HU, Infinity Reference 6.5 componets. Kenwood KAC-9104 1800w AMP, Kenwood KAC-8404 600w AMP, Subthump Stealth enclosure, PPI PRO104 2000 watt DVC Sub
sigpicTags: None
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
I have a UMI but they work on the same principle.
There should be 2 jam nuts that keep it from turning, just loosen them up and rotate the center hex nut.
Works just like a turn buckle.
You want apposing angles so if the trans is +2* then you want the rear at 0 - -2*.
Can also go the other way -2 and 2.
InActive Member
- April 11th, 2009
- 274
- Christopher
- 1998 Trans Am
- Battle Creek, MI.
where do you put the gauge to get the measurements?1998 Pontiac Trans Am LS1, Ram Air, White with custom Ghost Flames, Black Leather Interior, T-Tops, T56 Trans, 4.10 Rear End, Spohn Adjustable Torque Arm, Line Lock, Kooks Headers, Kooks ORY Pipe, SLP Loudmouth II catback, LS6 Intake, K&N Air filter, Centerforce Dual friction Clutch, Lowered and "Conklinized"
See from what I have heard you should never have the read end positive. I could be wrong tho.Originally posted by Phantom383 View PostI have a UMI but they work on the same principle.
Post Whore
- August 24th, 2006
- 1140
- David
- 2009 Pontiac G8 GT
- Battle Creek. MI
- Grahpic Designer
There is a video on BMR's website on how to set the pinion angle. Here is the link, BMR Fabrications, it's right on the front page below the cars.2013 Cadillac ATS
