recommend a lt1 383 stroker kit
  • recommend a lt1 383 stroker kit
    with my car having 125,000 on the clock and climbing, and running nitrous this summer, i know ill be doing internal work at some point. i have a good amount saved for a stroker kit but im not to sure at what i would need. i know i want forged internals to handle nitrous. but other then that im kind of clueless
    was cruising summit and eagle seems to make a kit for a decent price. but im open to all suggestions.
    now do i want flat top pistons or dished? what size rod length? i need alot of help on this subject.
    top end is running a lt4 hot cam kit. so the cam lift with the 1.6 rockers is .525 intake .525 exhaust if that helps you help me
    thanks in advance everyone
    Callies crank, Manley rods, and Diamond pistons are a winning combination But I'd go with flat top pistons, unsure of rod length.
    2015 Silverado
      i think phantom383 will be the most knowledgeable on this one. good luck man!
        ok thanks for the tip ill look into all that
        lol im waiting for him to chim in thanks
          the pistons just depent on the commpression ratio you want. also i would recommend heads or head work to accomodate the extra cubes. you dont wanna choke it.
          Sold!
          www.fquick.com/lozanoa11
          94 Grand Cherokee (sold)
          95 Accord(for sale)
          99 Outback (snow destroyer)
            ya going to have my stock heads ported and a bigger intake but as for compression i dont know what i want. nothing crazy just a decent build stay around 10:1 or 11:1
              What is this going to be used as?? Just a street car? whats your HP goals
                Piece together some good internals and follow these steps.
                Get the compression up
                Get a big cam with lots of exhaust duration
                Get a stand alone fuel system
                Get a direct port
                Hit the car with a 250+ shot
                HOLD ON....
                  He went to the movies today but I bet he'll throw in his two cents later.
                  He's currently rebuilding my engine.
                  RED
                    bigger cubes eat up the cam. A mild cam in a 350 will seem smaller than stock in a 383
                      Well, do we have some competition here
                      A lot depends on what you really want to do with the car?
                      Eagle makes a really nice setup with H-beams for 1800 and can handle 600 + HP and has a 4130 crank I believe.
                      I did a setup like this for Yoeasy69 (Josh James) and he plans on doing a 125-150 shot that will get his car to 600HP easy.
                      Compression:
                      As far as compression goes if you don't plan on buying heads you are going to need a forged dished piston @ -8 cc's to keep your compression down.
                      Now rods:
                      H-beam like I said and I would go 5.7 long.
                      6" will get the wrist pin into the oil ring and that's not the best if you are going to street drive the car and shoot N2o.
                      If you want pwr get a N2o cam that is made for what you are going to do.
                      Comp makes some nice ones.
                      I would suggest heads though!
                      Top of the line would be AFR ( See Pace ) but there are others like Trick Flow, Eddelbrock and more.
                      If you do heads you want a 62-64cc chamber with a 195 head.
                      If you do heads then a Flat Top piston will get you 10.5 - 10.8 for compression.
                      N2o:
                      Don't know a lot about it but I can tell you to stay away from a Dry kit and go with a Wet kit or Direct port being the best.
                      And depending on the style you go with a 42 or bigger injector but that will depend on the size cam you get and HP out put of the motor.
                      Up grade that fuel pump also!!
                      Racetronix has a nice 255 in tank system.
                      Gauges:
                      Wideband hands down!!
                      Fuel pressure
                      These would be the top 2 then I would go for Oil pressure and what ever else you want/need.
                      If you do this right you will spend 6-7 grand with out trying
                        Uhmm, yeah....he's not kidding. Ask me how I know.
                        RED
                          His will be in a different form than yours but ya
                            lots of great info kyle thank you so much. lots to think about ima put a list together and post it here see what you guys think. good thing is i already have some stuff off the list u laid out. guages and wet kit (currently on the car 75 shot)
                              everything kyle told me to get off summit just ran me $5,200 (didnt buy anything )
                              thats without a gasket set and everything that will nickel and dime u to death
