I have a remote bleeder up on the fire wall. I also have a vacum pump bleeder. Do I just hook the pump up to the valve. Or do I have to pump clutch peddle to bleed it. And what should I use in it? dot3 brake fluid
bleeding the clutch
it had a check valve. Didn't need the power bleeder, but it made it easy to clean up. However that didn't fix my problem.
Some times its hard to get into 1st and 3rd. could it be the 5.0 shifter or some thing internal?SLP lid, smooth bellew, Kateck valve covers, Trextralia 700oz clutch, Pro 5.0 shifter, SLP loud mouth cat back. Torque Thrust M
Thats Matts old car isn't it. Does it have a bellhousing blanket of it?Originally posted by lawmanbsi View Postit had a check valve. Didn't need the power bleeder, but it made it easy to clean up. However that didn't fix my problem.
