i just got my short throw shifter. didnt come with any instructions. i dont think it looks very hard at all to install but im timid with anything i have never done. any tips or words of wisdom?
heres some pics of the new shifter (stock knob on it)
Pretty sure that you gotta yank the console. Also, probably a good time to change your trans fluid as that is the easiest way to fill it since you can pour it right down the hole. And I think that most put RTV around the base, but I'm not positive on that, Joel might know.
Take the Center console out, then there was a rubber boot over the shifter that comes off, then the 4 bolts holding on the shifter. Definetly put RTV on there...whoever did mine b4 didn't do that and it came loose and was leaking fluid all over the bottom of my car.
98 Trans Am WS.6 Cam
Heads
Intake
Full exhaust
More mods to come
Yup!
The little tabs in the bag that have the holes in them off center, those will let you install it forward or back of the stock location just a little bit.
And my B&M had a blue base on it that had B&M cut into it so if you don't see that then it could be a Pro 5.0 or Hurst.
