Master cylinder the same??
  • Master cylinder the same??
    Hello,
    I am prepping for my swap and need to know is there a difference between the LS1 master cylinder and the master cylinder from a 3.8? I have found some info that says their the same, and some that say their different?
    Thanks!
    Jack
    Either way you should replace it with one from a 01-02 model year since they upgraded the hydraulics.
      the part numbers are all coming up the same at autozone, but would you really trust that source? they were going to get me an LS1 oil pan for 69.00 when it came it was for an LT1
        clutch or brake u didnt say lol?
        The LS1 or Go Home Crew
        ASE master certified
          go to a dealer and check.
          Sold!
          www.fquick.com/lozanoa11
          94 Grand Cherokee (sold)
          95 Accord(for sale)
          99 Outback (snow destroyer)
            Well being that this is posted under the "driveline" section...
              mybad i was just going by new posts up top.
              to the op you got a pic of master of the 3.8 i coudl tell ya if i saw a pic, is the line comeing out of it a quick disconnect as well where it goes into the slave?
