S10 Posi on a Firebird???
  • S10 Posi on a Firebird???
    I spoke to a mechanic at Jen's Easter get together and he suggested using the rear axle off a Chevy S10 pickup instead of an Eaton or Z28 Rear. Is this possible and would it be worth looking into?
    No. No. No.
    Gov-loc is GARBAGE. It will break under the power level of an S10 with daily driving and even when it works it slips like shit.
    Plus an S-10 axle is setup for leafsprings while an f-body axle is setup for multilink. The widths probably wouldn't work either.
    Total waste of time and money. Pick up a Z28 axle and call it a day.
    SpeedDetroit Speedshop <Owner> Detroit's Only True Grassroots Speedshop
    http://gasfed.blogspot.com/
    Originally posted by KuruptWS6spd
    And yes my box is ALWAYS this clean
      i didnt realize there was a difference!?
        i was gonna say they are pretty much the same cheep 10 bolt axel.. but atleast the z28 SS trans am..ect was made for some kinda v8 power
          with the exception of the fact its a 7.5" 10 bolt.
            Gov-loc is a poorly engineered piece of crap.
            The Zexel Torsen differential that comes in a Z28 is very very good for stock to mildly modified power levels.
            PLUS the modifications needed to make a leaf-sprung axle into a multilink axle are totally not worth it.
            We've got the 7 3/8" (?) axle whereas most S-trucks that came with a limited-slip have the 8.5" axle. Both 10-bolts but different everything.
            Just lock this thread or something, it really need that little consideration.
              8.5" ?? since when dude? do the ZR2 s10s have 8.5s or something, cause i swear my neighbors ZQ8 sonoma has a 7.5" 10 bolt posi.
                yep they have the 7.5 its the same axel as in a basic f body the only difference is leaf mounts instead of coil... but i dont think any of the s-10s came with anything nicer that a basic 7.5 even with the posi out of a s10 its not going to be as nice as an SS or z28 posi its just a plain jane posi rear that will need the brackets moved and the whole axel centered to work... save the headache and find a decent one
                  they havent used the 8.5 10 bolt in a while i think that died off around the 2nd gen f body era... still cheep but not as bad as the 7.5 with a little work
                    i wouldnt even be surprised if its the same posi considering how few s10s/sonomas were zq8s
                      ya probably 95% of them are one wheel wounders... i havent seen many eaither it would be easier to find a posi out of an f body than an s10 or jimmy or whatever
                        Throw away all your ten bolts and do NINE BOLT swaps.
                        Oh yeah, you know you love that third gen awesomeness.
                        *Rockin the nine bolt borg warner since 2005*
                          yes but being a notch above cheep doesnt make it good...lol find a 12 bolt and call it a day
                            Sorry to punk all'yall, but you're solidly wrong.
                            The ZR2 S10s and some ZQ8 S10s came with a 8.5" 10-bolt axle. Some of the standard 4x4 and most of the 4x4 Blazers also came with this axle.
                            I promise you this isn't bull, you have NO idea how much research I had to do on this shit for a past friend.
                            Joelius - You assumed wrong. It's a totally different posi than the Torsen in the Camaro. Positive.
                              i wont believe it until i look under my neighbors truck again ( could be awhile its in storage ). im aware the 7.5s and 8.5s look nothing alike as i own one of each ... my 98 Z71 has the 8.5 and it looks significantly larger.
