Rebuild or buy used 4L60E for 98 LS1???
  • Rebuild or buy used 4L60E for 98 LS1???
    My tranny is toast. The car will not go into any gear FWD or REV. I believe that the pump gave out. I say this because the fluid level was fine before the trans went out and then after it went out the level showed overfilled when running or not running. I pulled the trans pan which was full of gray sludge. I have had an aftermarket 3400 Fuddle stall converter in the trans for the past 3 years. I also have a B&M trans cooler. The car has 110k miles.
    I have a limited budget and am wondering if I would be better off having someone local rebuild the trans or if I should buy a used trans. Does anyone know a good trans builder in West Michigan. Also does anyone here know where I can find a good used trans for under $500. Of course the trans will need to be a 4L60E for a 98-02 LS1. THANKS.
    I would check local ads and craigslist. A rebuild will probably cost over $500
      Mike Ridings can build it for you and I believe he is a site sponsor.
        gonna cost well over 500 to rebuild it. check with west michigan transmission on 28th street
        West Michigan Firebird Club
        www.wmfirebird.com
          Are they any good?
            It will be over 500 to rebuild.
            It will cost over 500 to build, especially if the converter exploded. Give me a call, i'll try to keep it as painless as possible, you have my word on that. I can take care of the converter as well.
            586-255-3426.
            Mike.
