Need my T-56 trans rebuilt to handle around ......570+hp and a 5000rpm drop-clutch launch . Got the clutch and fly wheel. Any body got any good refrences for a mid michigan shop?
Wanted: bad ass T-56 Rebuild done localy
pretty much the best you are going to find anywhere...
http://danddperformance.com/ and they are in wixom, mi
Edit: also i forgot about liberty trans as well
i bought my trans parts from D&D but rebuilt it myself.. its actually quite simple as long as you know the order of assembly which you record when you take it apart. Saves TONS of money
here are some of the pics of my rebuild, actually i only took pics of the disassembly.. http://www.mifbody.com/vbulletin/showthread.php?t=15125Last edited by DanO; December 31st, 2008, 10:10 AM.
Dand D
my dad got parts from them for his trans... Dont us 6 speeds inc, they jacked my dads trans up badly and ive heard nothing but bad things about them.
A little closer (than Wixom) is Mike Ridings with Ridings Transmissions. He does awesome work and doesn't have the overhead that a lot of the other shops have.Last edited by meissen; December 31st, 2008, 10:08 AM.- Brian Meissen
we just delt with 6 speeds inc like 2 months ago, there closed since then?1997 Camaro SS convertible #594-Gone but never forgotten
I consider myself to be pretty good mechanicly, so maybe I will tackle it myself. Total time it took to rebuild and reinstall was what? 8 hrs? I'm guessing because it doesn't shift smoothly and never has I also have bent forks. Does this sound right?97 ws6, m6, le2, moser, spec 3, bla bla bla.
before le2 295hp(actual dyno), 1/4 @ 13.1 . No new numbers yet.
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
Originally posted by 1BADAIR View Postyou may or may not need a puller to get 5/6 off the shaft.
this is what they look like apart
larry.. you're just unorganized..lol
not to scare anyone.. here are the parts layed out in order of dissasembly.. (starting from the top left to bottom left, then top right to bottom right)
Um.... ya, thats allot of parts. I'd have a puller collecting dust in my garage after that. I'm going to have to export the job.97 ws6, m6, le2, moser, spec 3, bla bla bla.
Not a real hard trans to build.
The shop manual is online. If you take your time and lay out all the parts, you'll be ok. Paul at liberty can supply the parts necessary. The parts list: steel 3-4 fork, brass fork pads for 1-2, 3-4 synchro's (5-6 optional), and billet keys. The other stuff is standard stuff like carbon friction rings, bearings, etc.Originally posted by T/A Johnson View PostI consider myself to be pretty good mechanicly, so maybe I will tackle it myself. Total time it took to rebuild and reinstall was what? 8 hrs? I'm guessing because it doesn't shift smoothly and never has I also have bent forks. Does this sound right?
Use a little propane on the two torx headed bolts that retaing the forks/rails. They have loctite on them and they are brittle.
You can always call me for advice or help anytime 586-255-3426.
Mike.
