So, I've decided to do a T56 swap, and I have finally found a way to pay for it.
Here's what I know. The 1994-1997 T56's used in F-Bodies were mostly identical. They are the same as the 1998-2002 T56's except the LS1 T56's had a longer input shaft. The PCM in '94-'02 vehicles interacted with the T56 transmission, whereas the '93 had a slightly weaker version of the T56, and the PCM didn't control the transmission at all.
This is where my questions come in:
-1994+ T56-equipped vehicles had the "Skip Shift" feature that we hear so much about, while the 1993 T56 did not. Is it possible to use a 1994+ T56 transmission in a 1993 vehicle? Will I need to get a "Skip Shift Eliminator", or will the lack of input from the 1993 PCM eliminate the "Skip Shift" feature?
-The T56 transmission has a different spline count for the VSS (Vehicle Speed Sensor), is there a device or solution to correct the Speedometer?
-Are there any special considerations that need to be taken into account for the 1993 model year specifically? Any additional parts needed? Any parts normally used for '94-'97 that I won't need?
