f-in issues with my car
  • f-in issues with my car
    out of the blue my power steering pump started whnining and no power steering. fluid was a little low, added some and it didnt make a difference. im praying its only the pump and not the rack. anyone have a spare lying around? also at the same time my front brakes started grinding. so with these new issues and some of the other stuff, like bad drivers window motor, bad outer tie rods, leaking exhaust, bad battery/alternator, im thinking of putting my car away for the year. its just starting to nickel and dime me to death, and thats not even the stuff i want to do to it. also im noticing the car gets real squirrely at higher speeds. unsure what it is. i have newer shocks and springs and replaced the sway bar bushings front and rear. what else could it be? somebody please give me a reason to keep the car out!
    - - 5.3/4L80e/T7875 - -
    - Huron Speed Turbo Kit -
    1998 Formula
    keep it out cause its fun to drive
    my car gets squirrley at high speeds as well idk wtf it is
    sounds like ur pump is bad
    ls1tech usually is the best place to get that stuff they run from 70-90shipped
    The LS1 or Go Home Crew
    ASE master certified
      It wouldn't be whining if it was the rack. Fix the pump along with all the other maintenance that you would have to do with any other car once it starts getting old and go have fun with it.
      Shit my car needs an alignment, 4 new tires ect. and I still drive the thing because I enjoy it to much
        and a trans quit blowin all your money on chicks and put some into your damn car campbell!
          thanks guys. im getting a new pump tomorrow hopefully and the rest of the lil stuff ill try and tackle when i can. guess i should take it easy on her for a while. yeah the rear end likes to get going back and forth pretty good. its not an up and down squirrelly, more of a side to side. anyone have any ideas?
          1998 Formula
            panhard? lca's?
