t-56+sbc?
  • t-56+sbc?
    Will a t-56 bolt up to a gen one sbc? do i need an adapter plate? and does it matter if its a one or two piece rear main seal?
    Sold!
    www.fquick.com/lozanoa11
    94 Grand Cherokee (sold)
    95 Accord(for sale)
    99 Outback (snow destroyer)
    it will but i beleive you need a lt1 t56 as the ls1 style won;t bolt right up
      Yep...been done thousands of times.....just get a LT1 t56 and a GenI conversion flywheel from Centerforce or Mcleod. I had one for a few years sitting behind a 70's era 350 and Project DZ74 has one sitting behind it's 70's era LT motor.
        t56 is bold up to 87 and up 1 piece rear main engines, as james said, need a new conversion flywheel is using a 2 piece rear main engine. i think the LS1 T56 has the same bellhouisng bolt pattern, but is 2 inches shorter or something, or so i read on thirdgen.org....i'd double check that route if you found one.
        1967 chevy sportvan deluxe-fun cruiser
        1973 Chevy K10-woodhauling plow king
        2007 crewcab Z71, GFX limited edition- DD
        1992 Camaro Z28- LQ9/ T56 swap, TSP torquer cam, milled 243s, ls6 intake, stainless works longtubes, hand fabricated xpipes duals with magnaflows, 4"CAI
          ok ill just look for a lt1 trans. how much power can they hold up to. I don't wanna do all this work and blow it up. im looking to make 500 hp n/a and 600+ with spray. i know ill need a better clutch but am i gunna need a aftermarket trans?
          Sold!
          95 Accord(for sale)
            the LT1 T56 is rated for 450, not sure if they take more or not to blow them up.
              Depends on how you drive it. Some guys thrash and trash a t-56 behind a stock motor....other's can make them last behind 500+hp motors.
                well i plan on raceing it some so maby id be better with a performance one. sixspeedsinc.com has some kits do you guys know of any others?
                Sold!
                95 Accord(for sale)
