Saw this on TGO
  • Saw this on TGO
    Saw this on tgo and was wondering where I could get one
    http://www.thirdgen.org/techboard/tr...able+corrector
    Sonnax AS1-01K TV Cable Corrector
    Ebay.
      They work! Will break your neck when hitting second if you're not careful.
      Clamaped up tighter than a 15 year old on her first prom date...
        Well I already have a shift kit too. And with an open differencial the torque steer is quite noticable in the rear at the 1-2 shift. So when I get this then it should be even better.
        Where is a good place to get one? anything thats local or in the state?
          NPD..Maybe
          **** FEAR THIS ! ***
            If you are getting "torque steer" out of the rear, you have other issues you need to address before screwing around with your trans my friend.
              Torque Steer? Rear? Am I missing something?
                well what I mean is that I have an open differencial and when I gun it while rolling when it shifts into second gear the rear of the car slightly jerks to the right. like the right rear tire plants itself before the left rear tire. Sorry I didn't explain it very well.
                  Me thinks you need new LCA's with poly/rod ends. Sounds like your rubber bushings are shot in your LCA's causing unwanted forward/aft movement of the axle when the one tire grabs traction and the other is just along for the ride.
                    Well I am gladly exepting donations... But I will be puting in posi when I do that, No point in building up an open diff, I also think I need new axle bearings, Can hear a little whirring noise in the rear.
                    It doesn't do it all the time, Mostly does it when I go WOT up a hill by my house (I don't use 30th street anymore, they put gravel dowm on it...)
                      Donations... I dont think so.. not when yur getting free information that you could be paying for.
