Found the Problem! (Trans)
  • Found the Problem! (Trans)
    after slacking off on fixing the trans, i have got motivation to rebuild it for going to the track next week...
    Long story short..
    3-4 shift for was bent, added constant pressure to 3rd gear syncro, eventually broke the slider keys. Syncro friction overheated the oil and the combination of highway speeds and high friction locked my trans in gear.
    see.. its was simple
    Needless to say, that damaged the surface for the syncro.. so i need to buy a new gear..
    I'll let Pictures do the talking!
    which vehicle are we talking about?
      im guessin the camaro... the cobalt would be under warranty i would guess. glad you found the problem tho. how much is this fix gonna cost you tho?
        yeah its the camaro (t-56 trans)
        new gear is $119.. so not too bad, but not cheap either
        but i already bought the syncro rebuild kit to get the carbon fiber friction material, steel shift fork, bronze fork pads, and billet 3/4 keys..
        i will say the upgraded syncros are much better than stock... the static and dynamic coefficients of friction are much closer together.. they did their homework with this material vs the stock stuff. If im not mistaken anything 2001 and after had these from the factory..
          good job, that mean I get to see it run at milan?
            if i can get the gear quickly then yes...
              you will love how it feels when its done, believe me.
              Im happy my stuff is holding together still at 92k ... I am not a gentle with that pistol grip
              On the other hand, i like to double clutch around town alot so that probably saves wear.
                hey, yours looks differant than mine.
                just got them back a few hours ago.
                that used to be a yearly thing for my stuff
                No more syncros for me
                  lol!
                  yeah.. but i enjoy smooth shifts!! haha
                  thats definately beefy! should hold up great but be a pain for driving around town!
                    haha wow youre crazy larry
                      larry, my only question is what order was the machining and welding done..
                      i.e. how did they maintain the roundness, surface finish, and heat treat on the bearing race after welding?
                      If it was welded, heat treated, and then machined.. that would work, but other orders make me wonder..
                        not sure.
                        All I do know is that the micronite polish made it so shiny I don't want to put them back in the trans
                          yeah, i just ask because i do that kind of stuff all the time.. and have seen it done wrong far too many times.. It would be a good question to ask the supplier of that part..
                            liberty trans is the only one that modifies the T56
