If you're only lowering an inch or so you shouldn't throw off the pinion angle enough to cause vibration. You'll probably want to get lower control arm relocation brackets so you can correct the control arm angle as well as an adjustable panhard bar to recenter the rear since it will shift to one side being lowered.
Wade 2002 Camaro SS T Top Black M6 SLP 345HP 1985 Camaro IROC Z28 T Top Silver 305TPI Auto
unless you were maybe useing some springs that srop the heigh alot you'd need a adjustible torque arm, but lca relocation bracets+ my prokit and everything was good, but i did a few more things
sigpic The LS1 or Go Home Crew
ASE master certified 1998 Camarbo z28-going back to stock 11.3@121 old heads & cam setup
