I don't think they make a 3.90 for a 10 bolt do they?
as for et differances that is an open question. HP, RPM,tire size and more get factoredin for that
to be honest i dont know if they make 3.90s for a 10 bolt. i dont know much about rear ends
if they do there can't be a big difference between the two. if you were splitting hairs then yes but if its street/strip cant see the diffence being extreamly noticable
There's a range of ratio you want to achieve for first gear for launching. From what I can find you should have a 2.66 first gear ratio. Assuming you have a 26 inch tall tire, multiply the first gear ratio X the rear. You want this to fall between 8 -10. The farther over 10, the more like a creeper it will be, under 8, and you lose that grunt that you want.
2.66 X 3.90 = 7.9:1
2.66 X 4.10 = 10.9:1
So, if you want my recommendation, 3.73 would be perfect, gives you a 9.92:1. Yes, you will lose a little mileage probably, but with a 6 speed I can't believe it will be much, that's not a big jump. And if your tires are larger or smaller in overall height than 26 inches, you will have to adjust what your rear gear would be.
