T-56 Rebuild (site sponsors/anyone/Long Post)
  • T-56 Rebuild (site sponsors/anyone/Long Post)
    O.k. here is my problem!
    I have a 93 TA with the T-56 and I have a BAD vibration problem @ 60mph.
    From what I can tell it's speed related and not RPM because I can run 1st-?? till I hit 60-65mph before it kicks in an dthen won't go away till I get back down to 45 or so.
    It don't matter what gear I'm in either so I don't know if it's even my trany giving me the problem but It's the only part I haven't replace in the whole car.
    The motor is a 383, clutch is a Center Force Dual Frction, Fly Wheel is a SLP unit, motor mounts are new Energy Suspenssion, Trany mount is a Energy Suspenssion, UMI parts are Torque Arm, LCA's, Panhard Bar,
    Drive Shaft is a 3" aftermarket unit, new U-joints, balanaced by Weller Automotive, Marosso U-Joint Girddles and the Rear end is a Ford 9" with 4.10's and a locker, tires are new and freshlly balance before winter.
    I also replace the bearing in the tail end of the trany because it seemed to have more movement that it should.
    Pinion angles are opposite of each other with the tranny being positive 2* and the rear being -2-4* with a fully loaded suspenssion.
    Now before you say it the rear or the drive shaft is my problem I had this problem with the stock stuff & stock rear in the car so that is why I'm leaning twards the trany but then again that might not even be my problem??
    I notice the problem at the M10 event 3yrs ago and it freaked me out!
    This was after the new clutch/flywheel install.
    I used Red thread lock on new ARP bolts all a round and torqued to spec.
    Trany was also drained and had new fluit put in it and no I can't remember what kind but it was DOT aproved.
    From what I know about the car this is the original trany with almost 90,000 on it.
    I can fell the vibration in the seat of my pants, in my shifter handle and the stupid thing fells like it's going to come right through the floor of the car when it happens.
    I have no vibration in my stearing wheel at all, smooth and steady there.
    The motor is solid in the car and don't jump around like it's loose.
    I'm looking for someone who can help me fix/find this problem!
    I'm sick of not being able to enjoy the toy I have built
    I'm also tired of laying on my back in my garage trying to fix this thing
    I also found these guys on the net: http://ddperformance.com/
    Anyone heard of them??
    They are in Wixom, Mi. and would be a last resort if I need to rebuild the whole thing unless a site sponsor can do it and beat there price
    Any ideas are welcome!
    Having the same problem with my Sonoma right now. I think it may be the motor mounts, but I'm to lazy to crawl around my car in the cold.
    1997 Trans Am
    www.fquick.com/transampimp
      I changed mine because I thought that they were the problem
        if i were you i would look into just getting a transmission from a 94-97 car. you could probably ebay the one you have, stating the issue, for nearly as much as you bought the newer one for. And then youve got a stronger trans to boot.
          T-56rebuilds.com is the best I've seen and some of the strongest by far
            I believe T-56 rebuilds had the F-body 6 speed 1/4 record for a long while until Speed Inc. Just took it a few weeks back.
              $1900 and you could have yourself a brand spanking new one!
                Are you sure your flywheel's not out of balance? Seems odd it would start just after a clutch/flywheel install.
                Wade
                  That would make it RPM related, not speed unless it some weird harmonics going on there.
                    Well, you can have an out of balance tire that only vibrates at certain speeds. I would think the same would be possible for a flywheel.
                    Wade
                      I didn't think of that!
                      But wouldn't I feel that while the motor is running?
                      And I only feel it when the car is under a load.
                      Now when I dynoed the car I didn't feel a thing and we beat on that sucker
                        t56 rebuilds IS Six Speed Inc. now
                          Have your driveshaft balanced lt1's have lots of problems with driveshafts. and or A U joint..
                            Read my post, I did.
                              Talk to Amber at Six Speeds INC... She may habve something for you!
                              Sona Avedian
                              https://www.facebook.com/sona.avedyan
                              2001 Pontiac "TRANS" I AM ws6: 8s on easy
