93 TA Posi Making Noise
  • 93 TA Posi Making Noise
    Ive got a 93 ta and im assuming the rear end is posi, but whenever i turn either way it will make this high pitch noise, the fluid is at correct level.
    99 Grand Prix GT - Winter Ride
    ___M&R Electronics ___
    .MECP & ASE Certified.
    is it a squeak? if so thats a common problem, nothing is wrong. the g-force on the wheel forces the rotor to make contact with the barke pad (or something like that). my car does it, always has.
      yeah its a LOUD sqweak when i turn left, and no so bad when i turn right.
        does it do it when going slow around corners?
          yes, except when im moving slower say turning out of taco bell for example its more of a grind.... the car drive fine straight, no noises vibrations or grinds
            huh ya ive got the same problem on my truck. i thought maybe my break pad was lifting off its bracket. i was gonna try those NPS pads. the ones with the spikes that keep the pad attached. hmm. guess i don't need to anymore. is there anything that fixes this prob joel?
              hmm i dont think a grinding is normal, but hard to say.
                mine just squeaks around corners at slow speeds. sometimes i can hear it in a straight line but that's very seldom.
                  it doesnt sound like brake pads, to intense of a sqweaking noise.
