Synchro Rebuild Question
  • Synchro Rebuild Question
    Well, I'm going to need to replace the reverse synchro soon, and while I'm at it the 3/4 would be happy to have a new synchro...so might as well do them all. But anyway, how hard is it to replace the synchros? This includes removing the transmission, taking it apart, everything needed to do the fix. I've never worked on transmissions before, but can say that I'm not a retard mechanically (done a cam swap, valvetrain upgrade, rear end work, etc). I have the rebuild manual to help out, just asking for some personal experiences. Thanks everyone!
    1995 Trans Am Firebird. LT1 with 6 Speed manual. cc503 Cam. Pacesetter long tubes with true dual exhaust. LPE CAI. K&N. 4.10 Gears. ZR1 Replica Rims. Comp Cams 1.6 Roller Rockers. Double roller timing chain. BMR Sub Frame connectors. LT4 Knock Mod. Madz28 tune. Pro 5.0 shifter. LS1 Driveshaft. MSD Coil. Sequential Taillights. Custom Interior. Lead foot.
    CarDomain
    Time Slip: 1/4 -- 12.49 @ 116 MPH
    you might want to talk to john (phenomic). He just screwed up his trans and is going to be pulling it soon to fix it up too.
      D&D performance in wixom is the bomb. Thats where Id take it.
        yeah they did mine once before.... the walsh crew know their shit. and Dave (cameron) who works there has always helped me out!!
        1998 Camaro SS Bullseye Turbo
          If the syncro is screwed the gear most likely will need to be replaced too. Reverse sycro is brass. The reverse gear can be turned over so It probably won't need to be replaced.
          if you take is apart install at least the 3-4 billet keys and brass fork pads, and steel 3-4 fork
            i've done the t-5 tranny a dozen times at college this winter i'll attempt the t56 but if you haven't had any experience i wouldn't try it as theres so much little stuff
            The LS1 or Go Home Crew
            ASE master certified
