so i have the monsoon system in my camaro and i want to change the hu and later speakers/subs. it says on crutchfield.com that some modifications need to make the hu fit? what will i have to modify?
and if i want to change speakers do i need to gut the system?
anyone with the monsoon have any suggestions?
sigpic 2002 z28 Camaro Red M6.
-Magnaflow Catback, 4.10's, Mosher Axels, TA Cover
SOLD:
1999 Camaro 3.8 Y87-White
yeah behind the deck or head unit is a plastic piece that will keep the normal size head unit from going in its place. Just use a dremel or similar to remove. I had to. The monsoon deck isnt very deep like normal aftermarket decks so the put a plastic L piece to support the rear of the monsoon deck. Just remove it and youll be fine.
00 ws6 vert a4 ( mods in garage ) 87 fullsize bronco ( 35 inch mud terrains ) 85 iroc ( lt1 and 6 speed ) honda 450r honda 400ex gf's
What Angie didn't mention though is that I had to entirely bypass the monsoon amplifier that is installed in the rear cargo deck in front of the spare tire. The monsoon amplifier is a piece of shit entirely. After I bypassed the amplifier the sound was 1000000x better.
if you don't have a dremel, take a hammer and place the wooden end on the piece that needs to come off. then slam your hand into the head of the hammer on the top side which is laying down. just becareful to retract your hand quickly so it does continue to move forward and cut yourself!
so how do i bypass the amp?
how much does it take to blow the monsoon speakers?
SOLD:
run speaker wires direct from the deck/headunit to the speakers. not much, ecspecially with some speakers that are 8 or 9 yrs old.
Actually, I found something even better. Go to the rear sail panel interior piece and find the amp. I'll find my thread that I posted, all you need to do is cut the wire from one side of the monsoon amp and then cut the respective wire on the other side of the amp, solder the two wires together and tada you've bypassed the amp without having to do run new wires.
The monsoon uses special speakers that only work with a very, very particular kind of speakers. If you put aftermarket speakers into your system but have it going through the Monsoon amp, it'll sound like complete shit. Her front speakers had absolutely no bass at all until I bypassed the amplifiers. Her rear seat speakers didn't work at all until bypassing the amp.
