you should be ok, you may have cooked a fuse. I've seen some worse things and not fried an amp
problem..
Member with Invalid Email Address
- March 25th, 2005
- 1806
- Steve Hayes
- '97 Grand Prix GTP
- Saraland AL/Lapeer MI
- Sell car and home audio
InActive Member
- August 29th, 2006
- 1456
- Josh C.
- 1997 Z28
- Fraser, MI
- Electro-Mechanical Engineer
A little bit of spark jump is normal, its just the voltage difference between the +12 VDC power wire and the unpowered amp causing it to arc. Next time I suggest connecting all your sub/amp wires first, then applying power Via the fuse block under the hood ( Assuming you have one, which you should if you dont) Its possible you busted a fuse but just to make sure, you did turn up the sub output on the radio right?The Chevy Camaro was built with a single purpose in mind which it executes flawlessly...Going very very fast in a straight line until your hair catches on fire.
