Door speaker replacement
  • Door speaker replacement
    Blew a door speaker today and need replacements. It's for a. Monsoon system in a convertible.
    When in doubt, Whip it out !
    I have some Camaro speakers, but they are for the rears If I remember correctly, when doing speakers in vehicles with Monsoon systems there are active crossovers in the amp that direct bass to one speaker and the mids and highs to another. Front speaker wires were soldered directly to speaker leads, with no quick connect harness. Two Black (-) and two Red (+) wires running to speaker in pairs. So you either have to go with factory speakers and re solder, or if you go aftermarket, you have to figure out which red and black combo is for highs, and which is for lows, you use the lows on the main speaker terminals, and then depending on the aftermarket speaker, there could be visible wires going to the tweeter that you can cut and run to the high red and black wires. I hope that made sense lol
    I just replaced speakers in a 98 a couple weeks ago and its the same.
    99 Trans am
    - SLP Air Take (LID)
    - Ported and Polished Throttle Body
    - LS6 Intake Manifold
    - 1 3/4 Long Tube Headers
    - 3" Y-Pipe
    - 3" Magnaflow Catback
    - Lower Control Arms
    Soon
    - Heads/Cam
    - 3600 or 4000 Stall
    - 3.73 Gears
      Might need to break out the factory service manual
        This may help as well.
        ls1tech.com/forums/stereo-electronics/612644-monsoon-faq.html
        99 Trans am
        - 3" Y-Pipe
        Soon
        - Heads/Cam
        - 3.73 Gears
          ran across a guy who has clarion component sets for sale. it has the separate tweeter and bass/mid. price is right (I'm definitely no audiophile) and who can hear great music over the exhaust anyway? thanks
