I've been looking around for an alternative to the Delco DVC subs as a temporary install since I coughed up a 6.5" sail subwoofer.
I didn't want to spend $75-100 on a temporary sub, and in the 6-6.75" area with dual voice coils (DVC), selection is quite slim.
Just FYI - Pyle does make a claimed "6.5" dual voice coil subwoofer for around $20 each.
So I bought a pair, since Pyle has traditionally been a very good brand over the years, especially some of their pro audio drivers.
Their old stuff is undoubtably much better, but just posting my experience with this, so others can avoid wasting time.
The speakers arrived this afternoon, and I was quite pleased with the appearance of the drivers. Sewn cones, nice rubber surround, 30 oz magnet, and overall a solid looking 6" driver.
Then... came the issues:
Size does matter:
The model of these particular drivers are PLPW6D. There is quite a bit of confusion on size as the box quotes a 6" driver, yet a sticker and the advertisement claims to be a 6.5" driver. If you are using them for the sail panel subs, your holes will not line up. If you rotate the driver, you will need to drill new holes. Depth wasn't an issue as these are just shy of 3".
Quality issues right out of the box:
If you notice in the photo below... you'll see that the flange doesn't look quite right.
That's because it's bent. So much so that the cone is separating from the basket. The box was in good shape, so somebody was sleeping on the line, and they must not have any quality control..
Second sub - popped it out of the box, and at first appeared ok. So I tried to put it in the sail panel location, but would not fit unless I rotated it.
When laid flat, you could see the entire flange was improperly stamped and was bent to one side.
I did not power either sub up so I cannot speak for their performance. Pointless if they can't be mounted properly or if the manufacturing is that poor.
So, in conclusion you may want to skip this sub selection, or if you do partake - inspect very closely.
I'm going to save my coin, and upgrade all of the speakers at the same time with the amplifier rack etc.
Size does matter:
