if u want bass i recommend saving for this it packs a big punch man if u are at woodward i can let u hear mine
great use for dead sapce and u can still use t-tops =) http://www.ws6project.com/user_stor/...er-custom-box/
2000 WS.6 Build <--- click to see
I actually have that style of pocket sub box that I am going to try first. If it's not enough with the rest of the system, I may upgrade to something bigger.
If the single 10 works, I'll be selling my Premier Flat 12's.
do you have any pics or sound clips of how the pocket style box sounds and looks?
Soon. I am working on a temporary install until I get the funds for the full setup.
Here's the pocket sub box and the Pioneer Piston style driver.
4 Ohm, 1000W, built for small enclosures. This was the new model that replaced the lower wattage unit and is supposed to have more excursion capability.
Need to poly fill, adjust fit/finish, and install 8-10ga wire for the sub. The car is already wired with power/RCA's, just need time and $ to finish things.
I have an old amp I repaired that I will use temporaraly just for this summer.
I like the ttop box, but it looks like it is too tall. Will the cargo cover be useless with the box? I would like to be able to keep everything hidden under the cargo cover if possible.
Well I can't speak for fitment on a 3rd gen, but the 4th Gen Subthumb boxes leave a void on the drives side, and I don't believe you can use the flip down cargo cover due to the box replacing the area where it would sit. It might go down with some adjustment, but would be pointless with drivers behind it.
So, I may go with the Q-Logic. It doesn't leave voids on the sides, it's a little cheaper, and it's ready to order. I just don't like the funky divider in the center.
Then again, there is the option to make my own since I have the extra vinyl....
