Cb radio questions
  • Cb radio questions
    I have always wondered can you wire a cb radio to the existing antenna, i have one sitting around i wouldnt mind messing with but i dont want an antenna on my car, and our cars (4th gen) arent metal enough to use a magnetic one
    1996 Base Model
    +2 cylinder mod
    You probably could. I have an old magnetic CB antenna somewhere and the plug looked like it had two leads.
    Used to own a Firebird.
      i don even use the radio in my car, i usually use ipod or cds, so even if i have to use the end that goes to my head unit i would
      1996 Base Model
      +2 cylinder mod
        Radio antenas are tunes to the frequency bandwith, you will get some reception but not optimum reception.
          Even the bendy antennas that seemed to come on cars with bose?
          its longer then my CB one too
          1996 Base Model
          +2 cylinder mod
            If your not wanting the Giant antenna there is a smaller window one they make, when I had my CB in my camaro this worked great.
            just attached to the window glass and ran the cable up, really simple. not to noticable. you can adjust how it is angled as well
            can't even tell it's there with the right angle
            as for a mounting place this is where mine was
            hope some of these help
            1978 Chevy Malibu Classic:
            350 Crate Swap, Turbo 350 Transmission, Flowtech Full length Headers, Flowmaster 40's Mufflers, Tru-Dual Exhaust, Goodmark 2in Cowl Hood, Northern Autoparts Racing Aluminum Radiator, Jasper Pearl Paint Job, Billet Specialities Vintec Wheels
            1994 Chevy Camaro: Sold
            Former Projectcamaro Member
              Where do you get antennas like that?
              how do you run the wire to it?
              the CB i have is a cobra almost the same as that
              1996 Base Model
              +2 cylinder mod
                behind one of the truck stops in sioux city they have a CB shop that is where I got mine, also you could probably find it at any big truck stop. As for running the wire I had my car apart enough that it was pretty simple for me. I believe I went through the back of the headliner leaving enough slack for the hatch to be completely open (not 100% sure about that) but i know it went down the sail panel to the floor, under the carpet on the passenger side, all the way to the front with cable to spare. It was a HUGE length of cable but it worked great. Cable came with the antenna and only cost me about 15.00 i think or 30.00 (keep in mind this was 2.5 to 3 years ago) I will think on it more although i am pretty sure that was how i did it. Worked great. Obviously removed the CD holder box thing under the radio to fit it in there. worked great.
                also, this is where I had my uh....what's it called....mic? the actual talkin part? i feel like an idiot, but I had it mounted on the side of the radio and did not interfear with the glovebox at all
                  Alright thanks.
                  What I dont get is how is that antenna any different then whats on the back of the car now?
                  1996 Base Model
                  +2 cylinder mod
                    When I had a CB in my 4th gen I had the magnetic stubby antenna stuck in the corner of the t-top spot. Seemed to work nicely.
                      I dont have t tops
                      1996 Base Model
                      +2 cylinder mod
                        I looked into this, I used to be real big into CBs but slowly got out of it. Look around on other car websites you'd be suprised what you will find. There is a FJ site where The guy had a magnetic antenna inside of the cab. Maybe you could hide something in your bumper but it won't get the best reception. It has to have a tuneable tip which car radios don't have
                          You could always do what I did with my radio antenna. Run it inside car between the rear quarter and interior trim by the spare tire.
                          Sorry about previous post. Did not realize you don't have t-tops.
                            just have an l bracket made that comes out of the back of the car to bolt to. frame out antenna then you just run 18 ft coax to set the tune right, thats how i seen it done in AZ on a 3rd gen
                              I like the fender Idea I might do it tomorrow if I have time and test it out.
