1996 Delco Bose
  • 1996 Delco Bose
    My stock bose radio dosnt play cds and has a cracked screen.
    Is there a kti or anything to fix it. Or would it be somthing I would have to send it in.
    My dad had the radio in our impala redone and it cost more then I think theyre worth.
    1996 Base Model
    +2 cylinder mod
    did you try a cd laser lens cleaner? and im pretty sure ebay has some dead radios you can use a screen from.
      I think I will check it out.
      And i tried some lens cleaners didnt help
      1996 Base Model
      +2 cylinder mod
        why not just get an aftermarket one?
        Sold!
        www.fquick.com/lozanoa11
        94 Grand Cherokee (sold)
        95 Accord(for sale)
        99 Outback (snow destroyer)
          If you want to replace it with the same model to keep the car original or if you had steering wheel controls you wanted to continue to use then I would pull the unit and look at the label at the part number. Use a search engine to find resellers of the same part number. The same radio may have been used in several different models. Many are sold at eBay. You may be able to find one with the auxilary input mod or you may be able to mod it yourself depending on the model.
            i have a jvc in it now
            i would rather have the stock bose one
            1996 Base Model
            +2 cylinder mod
              wow didnt even know u can do this
              Sold!
              95 Accord(for sale)
                There is a place in madison hgts called SPEC-MO,they repair speedometers and car radios.
                  Specmo is also in flint.
                    For the cracked screen, I just took out a square of that STUPID plastic stuff that electronics come in (finally found a use for it) and made it so that it fit where the old plastic one did. Can't tell the difference.
