power antenna probs
  • power antenna probs
    yesterday i pulled the bird out and took it down and put some gas and injector cleaner, sprayed her down and wiped dry. i hit the power button on my radio to find that the antenna only came half way up, i turned the radio back off and the antenna didnt go back down. i pushed the antenna the rest of the way down and i heard it finish cycling. i havent tried to lubricate it or anything, really dont know what to use. any ideas? thanks
    probably just dry, there usually is a plastic cable that pushes it up and pulls it down. Have some one hit the button while to gently pull to get it all the way up then wipe the antennae down with light oil ie: 3 in 1 then cycle a couple of times probably be alright.
      yeah ill have to try that. hopefully i wont need to replace it
