4th gen power wire
  • 4th gen power wire
    Where did you run your power wire for your amp through the firewall? Driver or pass. side? Post pics if you can. Last year I ran it through the door jam because I didn't want to tear my car all apart with like 2 weeks left. I'm looking for places to run it but doesn't seem like there is an easy way to do it. I'd like to run it down the drivers side if possible because I have a stealth box and my amp is on that side
    passenger side...under the pcm there should be a hole through the firewall
      I seen that on the Camaro but I'm trying not to run it down that side. Well, I don't care if I have to run it but I'd need a longer wire. What I had laying around last time fit running it down the drivers side PERFECT.
        ah gotcha
          i just did mine last week
          and did it just how sam said
          1996 Base Model
          +2 cylinder mod
            I just got in from looking again. I guess that's the way I'm going to have to route it. I'll just have to get some more wire.
              In the Z i removed the panels then i removed the seat belt and ran the heavy duty wire under the seat belt so it didnt Flex my panels, Then i ran it under the back panel and Around the spare tire and under the Rear carpet and came out to the amp. and for my ground i used the heavy duty seat belt bolt.
                did mine same way as Sam :X3:
                  you can go through the hhod cable hole
                    can anyone find a picture on this? i ran mine through the fender and behind the rubber in the door and my door needs to be slammed now I hate it, but my dad would NOT allow me to cut a hole in the firewall
                      I don't have a picture but it's impossible to miss. It's directly below the PCM on the passenger side. Getting to it from the interior is a bit of a pain but it's not too bad - you'll have to remove the passenger kick panel and the panel under the glovebox.
                        I just drilled a new hole thru the firewall on the driver side for my amp. I've got too much stuff running through the passenger side grommet already (pass. side window fix wires, shift light wires, etc)
                          Mine was run through the passenger side...then again, it was a 3rd gen.
                            I'll take a pic of the Camaro and show you. It seemed like a good place to run it but I didn't want to drive up into Flint to get more wire.
                              The post is a few months old but here are the pix of where i ran my 4awg throught the firewall on the passanger side
                              1998 Pontiac Trans Am LS1, Ram Air, White with custom Ghost Flames, Black Leather Interior, T-Tops, T56 Trans, 4.10 Rear End, Spohn Adjustable Torque Arm, Line Lock, Kooks Headers, Kooks ORY Pipe, SLP Loudmouth II catback, LS6 Intake, K&N Air filter, Centerforce Dual friction Clutch, Lowered and "Conklinized"
                              Pioneer D3 HU, Infinity Reference 6.5 componets. Kenwood KAC-9104 1800w AMP, Kenwood KAC-8404 600w AMP, Subthump Stealth enclosure, PPI PRO104 2000 watt DVC Sub
