Always check your...
  • Always check your...
    So I spent all day yesterday with my dad working on Red Alert's audio. I had tried my old head unit in the car a few months ago when finishing up the dash, but the faceplate wouldn't come on.
    For those that aren't familiar with my setup, I had hard-wired a 9 foot extension cord for my headunit's face plate using 2 cat-5 cables. I had the faceplate mounted in my sunvisor for awhile while the headunit was in the glovebox.
    I thought for sure that the issue was the cat5 male-to-male adapter that I was using because the pins cross every now and then and it doesn't get a good connection. So I told my dad let's get rid of the adapters and just solder the wires together. He reluctantly agreed, so we decided to do a cool setup. Even with the carPC's internals in the dash, there was still all the open space behind where the stock HVAC controls go in the 98+ dash. So, we put the headunit there and pushed it back far enough so I could still pop the carPC bezel in place, hiding the headunit. I took the cat5 and ran it through my center console and drilled a hole in the center console, then my dad and I soldered the wires together so the headunit's faceplate would be in the center console. Lift the lid and there was the faceplate. Well, we finish soldering all 16 cat-5 wires together and plug everything in. Alas, no go! It wouldn't turn on.
    Well, the headunit HAD to be dead, right?
    So we went to Best Buy and I bought a new headunit, a cheapy JVC model for $80, I'm only using it to power the speakers, the CarPC's speaker output goes into the AUX IN for the headunit, and the headunit then disperses it out to all the speakers. It was the easiest way to do it rather than put another amp in the back and have to run wires to and from the amp, etc.
    So I finish splicing the wiring harness together, very straight forward, go out there and plug everything in. Start the car and the headunit stays blacked out. WTF?
    ...and then I realized I pulled the radio fuse when I started the dash swap...
    Needless to say, I now have a sweet new headunit and the carPC's audio is 100% fully functional.
    Ouch, well, at least it was something simple. Been there before buddy, been there.
      that sucks big time, no return on the headunit?
        Well at least you figured it out
        I really want to see this at the M&G
          Already hacked up the wiring on the new one, so we're going to keep it. It's a lot better of a headunit, anyway. The other one was quite old.
            Sorry but
              no reason to be sorry, I think it's hilarious that's why I posted it
                Note to self... Let Brian fix your computers, not car. J/K buddy!
                I've been there though. Yesterday when putting the 355 in the 'vette my cousin put the carb adapter plate and carb on and realized he didn't put the gasket on between the adapter and intake. He tore everything apart (including fuel lines/cables), puts the gasket on, assembles everything again and steps back to notice the gasket that goes in between the carb/adapter was sitting on the roof. A 10 minute job took him well over an hour!
                  That's great!
                    Fail!
                      Sounds like 2 minutes and a test light would have saved you $100+ .
                      — Thomas Jefferson
                        Yessir.
                          LOL I did the same thing when I was wiring my cutout. I took out the cig lighter fuse to wire the cutout to it and totally forgot about it. When I got done and it didn't work, I was on tons of forums trying to figure out what I did wrong! That is, until I walked by the work bench and noticed the fuse laying there. I felt like such a dumbass!
                          At least everything works now, that's a good feeling!
                            You're special Brian.
                            Nah, I've done shit like that before, but I will say, I have a test light in my center console.
